Hi all.
I want you to check this phenomenon if you know this.
First. I got a Assembly and related parts and draws(I didn't make this and i am sw developer, don't know Solidworks detaily)
Second. I tried test many pattern, But this problem occur by only one pattern and this files. I could't Reproduce to use other files.
Can you see the ex1.jpg image?
This is the table image what Assembly file's draw file.
files struct like this.
-> A9HXXXXX.asm(.drw)
->A9HXXXXS010.part(.drw)
-> ...(010 -> 020 030 ... 080)
->A9HXXXXS0100.part(.drw)
->V116XXXXXXN.part
Cells amost linked part's propertys, Except wraped red.
So. problem happen If i do this.
1. open A9HXXXXX.SLDASM and A9HXXXXX.SLDDRW
2. open V116XXXXXXN.SLDPRT
3. V116XXXXXXN.SLDPRT save new name for instance V116XXXXXXN-1.SLDPART
4. open another Part and Drw Files for instance A9HXXXXS080.SLDPRT, A9HXXXXS080.SLDDRW
5. Save new name Part file for instance A9HXXXX-S0840.SLDPRT -> A9HXXXX-00AS080.SLDPRT
table's no 10 record was be linked V116~ File's
And the not linked two cell moved to no8 record.
But, No8 record still linked A9HXXXX-00AS080.SLDPRT file, just showed like that.
If i Edit No8's B and D field to blank. they are changed A9HXXXX-00AS080 and Mounting Plate.
I don't know why happen like this.
please teach me if you know reason of this phenomenon.
thank you.
