My Engineer created a backup of CREO data. All the files seem to be there and I preview them using CREO Viewer. However when I try to open the assemblies in Composer most of data appears but some assemblies or parts only the assembly names are added and there are no images.
I see the part number in the assembly tree but you can not tick the part to see it.
I tried opening just the assembly and I still do not see and nothing is imported.
Why can I not see all the parts and assemblies from CREO?
Is there something that needs to be done when the parts and assemblies are backed up from CREO?
I have tried different import/open settings and no difference.
Chris
Hi Chris,
you tried different import options? What about "Import free faces"?
In some cases the engineer used geo from the web. This models are simplified in most cases. So the model will come as an face-model not as an volume.
If the Option "Import free faces" isnt set, you will become structure Infos but no geometry.
Dirk
