Now I have to use intended bom to show Bounding Box Area & Thickness .
But it show in 2 row .
Is there any way to show cut list items in part only state BOM?
Simple answer is no.
Long answer, you can read the cutlist properties and add the to custom properties or config properties as static text.
Requires programing. No other way if you want to use cutlist generated size.
I hear your pain. We all are waiting for a simple solution to blank size properties within SW. To no avail. Unfortunately.
And that doesn't even brush on the missing link between gauge tables and parametrically linked properties.
Tanks Elmar
I search very mush in the lot of post to insert cutlist item in the custom properties . But i dont find any things . The only way is use macro .
Why the SW make two difference lists . In our company i must report a total bom involve sheet metal , tubing and assembling parts . By now , the sheet metal part (in the intended BOM ) appear in tow row and my manger become confuse by my report . If there is a way to insert cutlist item parametrically , i could report a good BOM .
Your screen shot shows you have asked for an indented BOM (with no numbering). If you asked for numbering, the second line would show 1.1. This will give a row for each assembly with rows below for each part in that assembly.
To show a parts-only BOM (which is what you want), just select the other option ("Parts Only")
Hi Bill
When In use part only , the bounding box is disappeared .
For some reason it is desired to use part only (in the reported BOM ) , But when i use parts only , the bounding box is disappeared .
The big problem is that we cant use cut list Items as a value of custom propriety .
I read all of permited syntax , but none cut list item be in the allowed syntax
Tanks
Any one ?
