Macro Help
Question asked by Taylor Reed on Aug 30, 2016
Latest reply on Aug 30, 2016 by Amen Allah Jlili
I am working on a research project and this code will work with break points but once they are removed it doesnt work! I have lowered the issue to it not selecting the proper plane, so i created a plane parallel to the surface i need to draw on and still not working right. i have the multiple selections commented out and have tried multiple different methods and it hates me. everything work up until the "build sides"
' C:\Users\HOH118\AppData\Local\Temp\swx5496\Macro1.swb - macro recorded on 08/03/16 by HOH118
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Set swApp = _
Application.SldWorks
'load Part
Set Part = swApp.OpenDoc6("C:\Users\HOH118\Desktop\semi_1.SLDPRT", 1, 0, "", longstatus, longwarnings)
swApp.ActivateDoc2 "semi", False, longstatus
Set Part = swApp.ActiveDoc
Dim myModelView As Object
'TOP
'Tables/Variables
       Dim H As Double, A As Double, L1 As Double, L2 As Double, T As Double, TL As Double, x As Double, TLs As Double
       Dim n As Integer, i As Integer
'Gap
        A = 0.01 'InputBox("How big of a gap?(keep smaller than quarter the length(0.1 for sides, .07 for top)")
' length of bump
        L1 = 0.01 'InputBox("Specify L1(front)")
        L2 = 0.01 'InputBox("Specify L2(rear)")
        H = 0.01 'InputBox("specify Height")
' Thickness of bump
        T = 0.01 'InputBox("Specify Thickness")
' lenght of platform
        TL = 0.28
        TLs = 0.4
' number of bumps
        n = 3 'InputBox("How many extrusions do you want?")
' spacing
        x = ((TL - n * T - 2 * A) / (n - 1))
'Build
        Part.ShowNamedView2 "*Front", 1
        Part.SketchManager.InsertSketch True
        boolstatus = Part.Extension.SelectByID2("", "FACE", 2.5354686515633, 0.196199939706639, 0.139999999999986, False, 0, Nothing, 0)
        Part.ClearSelection2 True
        Dim skSegment As Object
        Set skSegment = Part.SketchManager.CreateLine(2.62256, 0.39624, 0#, 2.62256 - L1, 0.39624, 0#)
        Set skSegment = Part.SketchManager.CreateLine(2.62256 - L1, 0.39624, 0#, 2.62256 - L1 - L2, 0.39624, 0#)
        Part.SetPickMode
        Set skSegment = Part.SketchManager.CreateLine(2.62256 - L1, 0.39624, 0#, 2.62256 - L1, 0.39624 + H, 0#)
        Part.SetPickMode
        Set skSegment = Part.SketchManager.CreateTangentArc(2.62256 - L1, 0.39624 + H, 0#, 2.62256, 0.39624, 0#, 4)
        Set skSegment = Part.SketchManager.CreateTangentArc(2.62256 - L1, 0.39624 + H, 0#, 2.62256 - L1 - L2, 0.39624, 0#, 2)
        boolstatus = Part.Extension.SelectByID2("sketch44", "SKETCHREGION", 2.60921172422904, 0.39942814122772, 0, True, 4, Nothing, 0)
        boolstatus = Part.Extension.SelectByID2("sketch44", "SKETCHREGION", 2.61887488731883, 0.39894498307323, 0, True, 4, Nothing, 0)
        boolstatus = Part.Extension.SelectByID2("sketch44", "SKETCH", 2.60921172422904, 0.39942814122772, 0, False, 4, Nothing, 0)
        Part.SelectionManager.EnableContourSelection = True
        Dim myFeature As Object
        Set myFeature = Part.FeatureManager.FeatureExtrusion2(True, False, True, 0, 0, T, T, False, False, False, False, 1.74532925199433E-02, 1.74532925199433E-02, False, False, False, False, False, True, True, 0, 0, False)
        Part.SelectionManager.EnableContourSelection = False
'translate
        boolstatus = Part.Extension.SelectByID2("Boss-Extrude18", "SOLIDBODY", 2.62043554987201, 0.404421032129638, 0.132200255518736, True, 0, Nothing, 0)
        boolstatus = Part.Extension.SelectByID2("Boss-Extrude18", "SOLIDBODY", 2.62043554987201, 0.404421032129638, 0.132200255518736, False, 1, Nothing, 0)
        Set myFeature = Part.FeatureManager.InsertMoveCopyBody2(0, 0, -A, 0, 2.61005990677298, 0.402340560138932, 0.115, 0, 0, 0, False, 1)
'replicate
          boolstatus = Part.Extension.SelectByID2("", "FACE", 2.62145504830096, 0.400809257677547, 0.122485083596739, False, 0, Nothing, 0)
          Part.ActivateSelectedFeature
          boolstatus = Part.Extension.SelectByID2("Line1@Sketch41", "EXTSKETCHSEGMENT", -2.46073845709474E-02, 0.39624, 0, True, 0, Nothing, 0)
          boolstatus = Part.Extension.SelectByID2("Boss-Extrude18", "BODYFEATURE", 2.62145504830096, 0.400809257677547, 0.122485083596739, False, 4, Nothing, 0)
          boolstatus = Part.Extension.SelectByID2("Line1@Sketch41", "EXTSKETCHSEGMENT", -2.46073845709474E-02, 0.39624, 0, True, 1, Nothing, 0)
          Set myFeature = Part.FeatureManager.FeatureLinearPattern4(n, x + T, 0, 0, False, False, "NULL", "NULL", True, False, False, False, False, False, True, True, False, False, 0, 0)
'Sides
'Tables/Variables
       Dim Hs As Double, a_s As Double, L1s As Double, L2s As Double, Ts As Double, xs As Double
       Dim ns As Integer
'Gap
        a_s = 0.01 'InputBox("How big of a gap?(keep smaller than quarter the length(0.1 for sides, .07 for top)")
' length of bump
        L1s = 0.01 ' InputBox("Specify L1(front)")
        L2s = 0.01 'InputBox("Specify L2(rear)")
        Hs = 0.01 'InputBox("specify Height")
' Thickness of bump
        Ts = 0.01 'InputBox("Specify Thickness")
' number of bumps
        ns = 3 'InputBox("How many extrusions do you want?")
' spacing
       x = ((TLs - ns * Ts - 2 * a_s) / (ns - 1))
'Build Sides
        'boolstatus = Part.Extension.SelectByID2("", "FACE", 2.65, 0.396239999999978, 0, False, 0, Nothing, 0)
        'boolstatus = Part.Extension.SelectByID2("Plane7", "PLANE", 0, 0, 0, False, 0, Nothing, 0)
        boolstatus = Part.Extension.SelectByID2("", "FACE", 2#, 0.39624, 0, False, 0, Nothing, 0)
        Set skSegment = Part.SketchManager.CreateLine(2.62256, -0.14, 0#, 2.62256 - L1s, -0.14, 0#)
        Part.SetPickMode
        Set skSegment = Part.SketchManager.CreateLine(2.62256 - L1s, -0.14, 0#, 2.62256 - L1s, -0.14 - Hs, 0#)
        Part.SetPickMode
        Set skSegment = Part.SketchManager.CreateLine(2.62256 - L1s, -0.14, 0#, 2.62256 - L1s - L2s, -0.14, 0#)
        Part.SetPickMode
        Set skSegment = Part.SketchManager.CreateTangentArc(2.62256 - L1s, -0.14 - Hs, 0#, 2.62256, -0.14, 0#, 2)
        Set skSegment = Part.SketchManager.CreateTangentArc(2.62256 - L1s - L2s, -0.14, 0#, 2.62256 - L1s, -0.14 - Hs, 0#, 2)
        boolstatus = Part.Extension.SelectByID2("Sketch45", "SKETCHREGION", 2.60777103006834, 0.157285249999984, 0.145508834727256, True, 4, Nothing, 0)
        boolstatus = Part.Extension.SelectByID2("Sketch45", "SKETCHREGION", 2.61648817213429, 0.157285249999984, 0.145218263325058, True, 4, Nothing, 0)
        boolstatus = Part.Extension.SelectByID2("Sketch45", "SKETCH", 2.60777103006834, 0.157285249999984, 0.145508834727256, False, 4, Nothing, 0)
        Set myFeature = Part.FeatureManager.FeatureExtrusion2(True, False, True, 0, 0, 0.01, 0.01, False, False, False, False, 1.74532925199433E-02, 1.74532925199433E-02, False, False, False, False, True, True, True, 0, 0, False)
