I might be missing a setting here, but somehow hatch pattern do not show up when I use the 'Save as PDF' function in SW2015.
All looks fine when I 'Print to PDF'. Any Ideas ... ?
Hi Rainer, is the view a Broken view by any chance?
There is an open SPR in the SolidWorks Knowledge Base:
I'm having this same issue using SW2019.
See if anything at How can I fix a poor quality PDF saved from a SolidWorks Drawing? will help.
try to print to pdf instead
