SW 2016 - Gaming laptop or MS SB/SP4?
Question asked by Mike Maciazka on Aug 28, 2016
Latest reply on Aug 29, 2016 by Tim Taby
Alright, I found a thread from earlier this year that was talking about using Surface Pro 4 for SW.  I'm intrigued by it, but I have a few questions.
I'll start with my background.  I'm a machinist and graduated this past spring from PMT (Precision Manufacturing Technology).  We had a 3D CAD class that utilized SW 2015...we were given student versions for at home.  I built a PC to run that at home.  And I will use that the next two years as well, but I want something portable.]]
I should mention the reason I want portable is that my PC is in my office...away from everything and everyone.  I would like to be able to use SW while on the couch or sitting somewhere else where my girlfriend and/or son are...to be able to work on things while still spending time with them.
My home PC has the following:
MicroATX form factorIntel Pentium G3258 Dual-Core CPU (OC'd to 4.2GHz)
16GB RAM (DDR3-1600)
Quadro K620 GPU
128GB SSD for OS
250GB SSD for storage
500W PS
Win 7 Pro
I plan to upgrade the PS to 700W+ and the RAM to 32GB.  I might also go to either an i5-4690k or i7-4790k.
This computer works pretty well for the basic stuff I've done in SW so far...the only problem with it is that I can't multitask...when I try to do browsing or stream music while working on models, it slows down a bit.  I built it with the G3258 knowing that SW relies on only a single core, but I think upgrading to a quad-core CPU might help in other areas outside of SW.
I work full-time and go to school full-time.  My budget is limited to about $2000.  I'd rather keep it below that if possible, but I'll give you a rundown of what I was looking at.
Originally I was looking at gaming PC's with the following specs:
15-17" display FHD
i7-6700HQ CPU (or higher)
16+ GB RAM
GeForce GTX 960m (or higher)
SSD or SSD/HDD combo
My main use would be SW, productivity, browsing, and photoshop.  Not much of a PC gamer, but it's an added perk if I do want to try it out.
Then I read a thread here about the SP4 for SW...and I was curious about the following:
SP4 - i5, 8GB, 256GB for $1150.
SP4 - i5, 16GB, 256GB for $1350.
SP4 - i7, 8GB, 256GB for $1439.10.
SP4 - i7, 16GB, 256GB for $1619.10.
NOTE: These prices are directly from Microsoft online store...I believe with my student discount since the first two are $150 off and the other two are 10% off.
I assume going for the 16GB RAM would be the better option, but I wasn't sure if the i7 was really needed.  From what I have read, the only reports of the SP4 running hot and throttling down was due to people using the i7...it appears some have used i5 with SW...but I don't know how well either works...any help here?
The reason I would like the Surface Pro or Surface Book is because it would have more benefit than the laptop would at school.  I wouldn't really be able to game on it, but I don't game as it is now....at school though, I could hand jot notes, draw, and do many other things I don't see myself doing on the gaming laptop.
Lastly, the SB...I don't know if I like the idea of the SB because in tablet form, I read it doesn't get very good battery life....but when attached to it's base it is fine.  The biggest perk to this for me is probably the dedicated GPU (although what I have read states that their best guess is it's equivalent to roughly a GeForce 940m...not a great GPU by any means, but definitely better than IGP).
If I got an SB, I would look at this configuration:
SB - i5, 8GB, 256GB, dGPU for $1709.10.
The i7 would be in my price range, but I really do not want to spend that much.  I would also like to factor a few accessories in to my $2000 budget as well.
On that note, do any of you have recommendations for what you would do if you were a student learning SW?  Laptop or Surface?  Specs?  And if you went the Surface route, what accessories would you add?
I'm looking at the keyboard and mouse for sure with the SP4 or mouse with the SB....possibly a skin/case for it as well.
Thank you so much for reading and responding.
P.S. I'm hoping to buy before we get too far into September since I already missed out on some of the back to school deals that Microsoft offered for the Surface.
Mike
