Dear friends,
I have done a static study of a structure, and now I want to perform a dynamic study with the same parameters Ioads, supports, materials...). What can I do?
Thank you very much and happy week end!
Regards,
Juan José
Dear friends,
Regards,
Juan José
Dear Christian,
At this moment I don't know, I think that everythem because we have it installed at University.
I have found that is possible to select one parameter (for example connections) and drag it until the other Simulation and then these characteristics will be applied. But I think that similar to Nastran in CAD, for example, could be duplicate the study and then change to the type of study required.
Regards,
JJ
I run 2015 sp5 and the drag and drop functionality is pretty busted - there is no sense on what works and what doesn't from study type to study type. They should adopt the make a model and then run what ever studies you want against it strategy. At the top of the tree you have was is universally supported by all studies, then under each study you have its results and anything peculiar to each specific type of study. This would likely be a complete architectural change but it would be worth it in terms of productivity.
What packages's license do you have now?
