TMTodd Mendez24/09/2008
I want to model a over molded part. I have the inner base
part and the outer over mold part. I want to cut/indent/remove the
volume of the inner part from the outer.
What is the easist method? I'm not doing a actual mold design, I just want to show the two parts seperately?
Is the Indent feature used only in a single model? The help gives a example of teh target bode and tool body? This option is not available in Assy mode. I'm confused? Do I need the solid bodies in the same model?
I have a screen shot attached showing the outer/inner part assembled. I want the outer part to have the cavity of the inner volume.
