1 Reply Latest reply on Nov 3, 2016 9:33 AM by Mihai Curecheru
    broken-out-Section line thickness wrong with DIN drafting standard
    Sascha Smolny
      we have a problem with wrong line thickness in broken-out-Sections. With our used DIN drafting standard (see rectangular profile in the middle):
      With ISO Drafting standard:
      What can cause this? Is it a wrong setting?
      We are using SolidWorks 2016 SP4.0
      Regards,
      Sascha
        • Re: broken-out-Section line thickness wrong with DIN drafting standard
          Mihai Curecheru
          I have the same problem, I use ISO standard and when I am doing broken-out section, the thikness of line is the same with thikness of visible edges. I tried to modify thikness of visible edges next way: Document properties ==> Line font ==> Visible Edges. And if I change the thikness of visible edges, it is changing automaticaly the thikness of broken-out section line.
          Like you, I am interested to know how can I change settings of SW to modify only the thikness of broken-out section line.
