Is there a way to change the text justification of BOM tables?
Currently, everything is centered. I would like everything left indented by 1. I do this in Excel all the time, but can't quite seem to figure out how to do it in an embedded SW BOM table in a drawing.
I have managed to change a single cell justification to left, center, or right, but that's about it.
I would also like to bold the column headers.
Ideally, I would change existing BOMs and then set up my document template to format them this way every time.
Thanks for any help, as always.
You can create a BOM template. Make changes to your BOM (text align an so on) then right click on BOM and save as template.
To use your BOM template settings you must check the option "Use template settings" from Options->Document Properties -> Tables, otherwise even when you use your BOM template the settings you made revert to default (centered..).
