9 Replies Latest reply on Aug 26, 2016 2:04 PM by Christian Chu
    Drawing Note Macro No Longer Working in SW2016
    Ian Chamberlin
      Greetings all...
      I have a macro that we use to populate drawing notes which was downloaded from Lenny Kikstra's site (CommonNotes v2.5).  This worked fine until we recently upgraded from 2012 to 2016.  The code is hanging at this line:
      FileTyp = Document.GetType
      This should determine the document type but I'm guessing it hangs here now because the syntax of the command has changed?  I don't have enough API knowledge to figure this out so I'm hoping someone can chime in to help me get this macro running again.
      Ian
        • Re: Drawing Note Macro No Longer Working in SW2016
          Christian Chu
          There are many changes in API from 2012 to 2016
          Try this:
          If swModelDoc.GetType <> swDocDRAWING Then
                  MsgBox "The active document is not a SW drawing", vbInformation, "Wrong Document Type"
                  End
          or post your macro here so we can take a look
              Ian Chamberlin
              Thanks for the response.  I tried replacing the relevant line but it still throws an error.  The current code is as follows:
              Global swApp    As Object
              Global Document As Object
              Global boolstatus   As Boolean
              Global longstatus   As Long
              Global SelMgr   As Object
              Global PickPt   As Variant
              Global CustomNote   As String
              Global Const swDocDRAWING = 3           ' Consistent with swconst.bas
              Global Const version = 2.55
                Set swApp = Application.SldWorks          ' Attach to SolidWorks
                Set Document = swApp.ActiveDoc            ' Get active document
                If Not Document Is Nothing Then           ' Document is valid
                  FileTyp = Document.GetType              ' Get document type
                  If FileTyp = swDocDRAWING Then          ' Is it a drawing ?
                    PickPt = Document.GetInsertionPoint   ' Get user selected point
                    If IsEmpty(PickPt) Then               ' Valid point
                      MsgBox "Please pick an insertion point before running macro.", _
                             vbExclamation
                    Else
                      FormSelectNotes.Show                ' Show user form
                  Else
                    MsgBox "Current document is not a drawing." & Chr(13) & Chr(13) _
                          & "Please load/activate a SolidWorks " & Chr(13) _
                          & "drawing and try again.", vbExclamation
                Else
                    MsgBox "No active drawing found in SolidWorks." & Chr(13) & Chr(13) _
              Is there any way to tag code chunks in these forum messages for better formatting?
                  Christian Chu
                  1) change  Public swApp As SldWorks.SldWorks
                  2) change long to longptr
                  3) change
                      If FileTyp = swDocDRAWING Then .... with
                  If Document.GetType <> 3 Then
                          End
                  make sure to check the ref. all up to 2016
                    Ivana Kolin
                    yes you can format your code.
                    Choose "advanced editor " and syntax highlighting - > Plain
                    Option Explicit
                    Global swApp                                      As SldWorks.SldWorks
                    Global swMod                                      As SldWorks.ModelDoc2
                    Global Document                                   As SldWorks.DrawingDoc
                    Dim FileTyp                                       As Integer
                        Set swMod = swApp.ActiveDoc                            ' Get active document
                        If Not swMod Is Nothing Then                           ' Document is valid
                            FileTyp = swMod.GetType                            ' Get document type
                                           vbExclamation
                                Else
                            Else
                        Else
                  Christian Chu
                  I copied your codes and pasted into a new macro and it works just fine (no error )
                  I created a form "FormSelectNotes", picked a point on the dwg and run the macro - see att. image - I also attached the macro here !!! Good luck
