When using Angular dimensions one has two options either it's CCW all the way or it's half and half (= bidirectional)
The other day for a client they wanted it to be clockwise. Is the only way to achieve that by faking it or is there a way to actual put angular dimensions down that way?
You can make angular running dimensions either cw or ccw based on the first feature you select after placing your 0deg baseline. You cannot switch a set between cw and ccw once created, however.
