Hi all,
Is it at all possible to shell out a specific contour rather than just a selected face?
Under the Shell properties tab I can't see any other options than to select an entire face which is not what I want to do so I was wondering if there was another way around this somehow?
Dave.
There would be one shot, add a sketch to the surface or project a sketch to the surface by using the Split Line Curve Feature/ Then when you want to shell the part just select that Split Line face and the rest will shell out and that face will be removed - See attached
