Can you help please?
I understand the way this works has changed in 2016 and currently, it isn't for me.
Trying to auto-populate the 'DrawnBy' entry in the DRW.
In the supplied vault (by the VAR) we havethe following for this filed -
Label - Created By
Assigned Vairable - Author
Drawing border property mapping - $PRP:"DrawnBy"
I have the Date (date drawn) working, and I have followed the variable route through from the workflow Transition Action, PDM Part & Drg cards, Part Template and Sheet format and tried about every combination I can imagine......still blank in the Drg after completing the Drg Data Card upon first save and check in.
If I use $PRPSHEET (which i've been told is wrong for this field), I can get 'Admin' to appear in the field as this is a set 'Value/Text Expression in the Part Template, but using $PRP , I cannot get it to work.
What is it that has changed in 2016 about Tempkates/Sheet formats?
Thank you.
Thank you for your responses, both...It was worse than I had imagined.
Been here a few weeks to administrate a VAR installed vault/setup and support Solidworks/PDM users etc and finally getting to do some vault dev.
It turned out that aspects of the vault implementation didn't match the documentation provided and some of the variables quoted and in place in Sheet formats hadn't even been created.
After a lengthy support chat...sorted. No longer confused.
And I've kept it simple by maintaining the name of the variable through the process....why complicate with several different Labels / Variables and mapping properties ?!?!
Now to workflow implementation.
Cheers.
Phil Lane.
