Is it possible to convert an assembly in one piece?
if it is possible, how can i do it?
Thanks for your answers.
If you want is one piece not a multi-body part then solidworks can not do it. the closest is saving it into a part but it will give you a multi body part
As Kevin has asked... What are you after when you get the parts together in one part file?
If you just save as and make a part file, you'll get multiple solid (or surface) bodies that you cannot edit as you once could. If you want to be able to edit both bodies (assuming that you started with two) then you need to do something different.
What about inserting on part into the other and then combining? You get all the features that make up the one part plus you get a combine feature that adds both parts together.
Steve C
Save as a SW part (sldprt)
or you can save as a step file or other 3D formats
