Hi all,
Is there a straight forward way to hyperlink files in the vault. I have seen posts that indicate there are issues with add ins, etc, but nothing seems conclusive...
Mike
Hi all,
Mike
DPS Germany has public Add-In to add folder to Windows Favorites, but I assume that this is not a tool which you are looking for?
You can find tool here :
Download-Center - DPS Software
Regards
Wojciech
Can you access files in EPDM via a hyperlink address?
This post from Charley is what I downloaded
Charley Saint Mar 4, 2016 11:29 AM (in response to Dale Bethwaite)
But then received this error message:
"Archive server could not open windows registry"
Then this was the solution, found in this post
Archive server could not open windows registry | MySolidWorks
Is this an add-in you downloaded? If so, it is likely that you just need to right-click on the .dll file and select "Unblock". Many times the issue with this error message is just simply a downloaded .dll file needs to be unblocked in order to allow it to run properly.
By: Jordan Lemley Fri, 06 May 2016 16:50:58 GMT
Thank you both for posting.
