After I upgraded to Windows 10 - I cannot save new documents without SolidWorks crashing.
I run it also in compatibility mode, but the error persists.
Any experience with that error?
Best,
David
Best,
David
If it's only on new documents I wonder if your templates may have gotten corrupted? Try opening an existing Part, delete all features and sketches, and save as Part Template (.prtdot) at the location you're pointing to at Tools > Options > System Options > File Locations > Document Templates. Now start a new Part with this template and see if you can save it. If that works repeat the process with an existing Assembly. If that doesn't work, and no one else replies with a different suggestion, it might be time to get your VAR involved.
