Recently, I designed my first global variable driven series of parts. I wrote a simple .txt file and linked each part to it.
This was a giant leap forward for me (I had not done much with global variables up to this point) and I could immediately see the many benefits of SolidWorks "automation".
However, I could also see some areas that I need to work on. For example, if I edited the text file after it was already linked to a part file (added a variable, renamed one, etc.), I then had to go into each part file and "relink" the text file, which is tedious and, well, quite boring.
Is there a way to avoid having to do this, to have each part auto query the .txt file and see if there have been any changes?
Also, the .txt file seems a bit old school, for lack of a better term. Is there a way to share global variables between parts in a more "GUI" type way?
Thanks for any help, as always.
Theoretically you can create direct link between Global Variables: Assembly <-> Parts or/and Assembly <-> Sub assemblies:
See:
2015 SOLIDWORKS Help - Equations in Assemblies
Equations worked fine in SW 2014, but since SW 2015 all links between Global Variables have been broken:
Parts in sub-assembly do not update
or
SW 2016 issue. Links between components Global Variables in assembly are broken.
Despite many SP (service performance) reports the issue is still exists and not clear if SW Development Team has any plan to fix it in a nearest future.
Link between Global Variables still may be established indirectly:
Global Variable of Top Level->dimension-in-sketch-of-Top-Level-Assembly-> dimension-in-sketch-of-Part (or Sub assembly)-> Global Variable-in-Part (or Sub assembly).
It works, but it is a real pain...
