Is there any way to export sheet metal flatpatterns where the bend lines and any sketches are a different color? Would make it a lot easier for laser/ cnc processing. TIA
I'm sure it's not the answer you want to hear!
The simplest way is to post process in DraftSight
Alternative in SW instead of export to dxf, you can create a drawing (blank 1:1) Select Flat Pattern
Then colour the required lines. The bend lines you can change the type of line but not the colour.
