0 Replies Latest reply on Aug 19, 2016 11:35 AM by John Lindskog
    API - Change the Configuration and Visibility of a Drawing View or BOM table.
    John Lindskog
      If you have a Macro that creates new configurations of a part or assembly, you may want a subroutine that can change the configuration of a drawing view or BOM Table in a drawing. This Macro does just that.
      Sub ChangeDrawingView(DrawingViewName As String, VisibleOrNot As Boolean, Optional Configuration As String) 'Written by John D. Lindskog
      'This subroutine changes the visibility and configuration of a drawing view or drawing bill of materials table. If the optional
      'configuration argument is ommitted or the VisibleOrNot Boolean is false or the configuration is not available then the
      'configuration is not changed.  This subroutine understandably does not change the configuration of Detail or Section Views.
      Dim swDrawingDoc As SldWorks.DrawingDoc
      Dim swSheet As SldWorks.Sheet
      Dim swView As SldWorks.View
      Dim swConfigMgr As SldWorks.ConfigurationManager
      Dim swConfiguration As SldWorks.Configuration
      Dim swBomFeature As SldWorks.BomFeature
      Dim swBomTableAnnotation As SldWorks.BomTableAnnotation
      Dim swTableAnnotation As SldWorks.TableAnnotation
      Dim swAnn As SldWorks.Annotation
      Set swDrawingDoc = swModel
      If swDrawingDoc Is Nothing Then                                             'If there is a problem then send a message
          MsgBox "The Drawing Doc object was not connected to the drawing ModelDoc2 object.", vbOKOnly, _
          "Object was not found by ChangeDrawingView function call."
          Exit Sub        'to the user and end the subroutine.
      Set swSelMgr = swModel.SelectionManager                                     'Connect to the Selection Manager.
      If swSelMgr Is Nothing Then                                                 'If there is a problem then send a message
          MsgBox "The Selection Manager object was not connected to the drawing ModelDoc2 object.", vbOKOnly, _
      swModel.Extension.SelectByID2 DrawingViewName, "DRAWINGVIEW", 0, 0, 0, False, 0, Nothing, 0
      Set swView = swSelMgr.GetSelectedObject6(1, -1)                             'Set the View object to the selected object
      If swView Is Nothing Then
          swModel.Extension.SelectByID2 DrawingViewName, "BOMFEATURE", 0, 0, 0, False, 0, Nothing, 0
          Set swBomFeature = swSelMgr.GetSelectedObject6(1, -1)                   'Set the BOM object to the selected object
          If swBomFeature Is Nothing Then
              MsgBox "Error selecting the object: " & DrawingViewName & ", please check name.", vbOKOnly, _
              Exit Sub
      Else
          Dim swViewSheet As SldWorks.Sheet                                       'Check to make sure the drawing sheet that the view
          Set swViewSheet = swView.Sheet                                          'is on is the active sheet.  If not, then change
          Set swSheet = swDrawingDoc.GetCurrentSheet                              'the active sheet and reacquire the view object.
          If Not StrComp(swSheet.GetName, swViewSheet.GetName, vbTextCompare) = 0 Then
              swDrawingDoc.ActivateSheet (swViewSheet.GetName)
                  MsgBox "Error selecting the drawing view object " & DrawingViewName & ", please check name.", vbOKOnly, _
                  Exit Sub
      If swSelMgr.GetSelectedObjectType3(1, -1) = swSelectType_e.swSelDRAWINGVIEWS Then
          swView.SetVisible VisibleOrNot, False                                   'Set the View visibility
          If Configuration = "" Then                                              'If configuration empty then
              swModel.EditRebuild3                                                'we are finished, redraw the window and
              Exit Sub                                                            'exit this subroutine.
          If swView.Type = SwConst.swDrawingViewTypes_e.swDrawingDetailView Then
              MsgBox "Error Changing Configuration of " & DrawingViewName, vbOKOnly, _
              "Detail View configurations cannot be changed by ChangeDrawingView function call."
              Exit Sub
          ElseIf swView.Type = SwConst.swDrawingViewTypes_e.swDrawingSectionView Then
              "Section Views configurations cannot be changed by ChangeDrawingView function call."
              Exit Sub
          If Not StrComp(Configuration, swView.ReferencedConfiguration, vbTextCompare) = 0 Then
              Dim swModelTempObject As SldWorks.ModelDoc2                         'Check if the view is already set to the desired
              Set swModelTempObject = swView.ReferencedDocument                   'configuration.  If not then change it.
              If Not swModelTempObject Is Nothing Then
                  Set swConfiguration = swModelTempObject.GetConfigurationByName(Configuration)
                  If Not swConfiguration Is Nothing Then
                      swView.ReferencedConfiguration = Configuration              'Change the View configuration.
                      swModel.EditRebuild3                                        'This function must be called to see config changes
                  Else
                      "ChangeDrawingView function call could not obtain Configuration object."
                      Exit Sub                                                    'If configuration is not available then send the
                  End If                                                          'user a message and exit this subroutine.
              Else
                  "ChangeDrawingView function call could not obtain View Part or Assembly object"
                  Exit Sub
      ElseIf swSelMgr.GetSelectedObjectType3(1, -1) = swSelectType_e.swSelBOMFEATURES Then
          Dim TableAnnotationsArray As Variant
          TableAnnotationsArray = swBomFeature.GetTableAnnotations                'Get TableAnnotationsArray from BomFeature object
          Set swBomTableAnnotation = TableAnnotationsArray(0)                     'Get BomTableAnnotation object from that array
          Set swTableAnnotation = swBomTableAnnotation                            'Get TableAnnotation object from that object
          Set swAnn = swTableAnnotation.GetAnnotation                             'Get Annotation object from that object
          If VisibleOrNot = True Then
              swAnn.Visible = swAnnotationVisibilityState_e.swAnnotationVisible   'Use the Annotation object to set the
              swModel.EditRebuild3                                                'Visibility of the BOM
          Else
              swAnn.Visible = swAnnotationVisibilityState_e.swAnnotationHidden
          If VisibleOrNot = False Or Configuration = "" Then
              swModel.EditRebuild3                                                'If BOM is hidden or configuration empty then
              Exit Sub                                                            'we are finished, exit the subroutine
          Dim ConfigurationCount As Integer
          ConfigurationCount = swBomFeature.GetConfigurationCount(False)
          Dim ConfigurationVisible As Variant
          Dim ConfigurationNames As Variant
          ConfigurationNames = swBomFeature.GetConfigurations(False, ConfigurationVisible)
          Dim count As Integer
          For count = 0 To ConfigurationCount - 1
              If StrComp(Configuration, ConfigurationNames(count), vbTextCompare) = 0 Then
                  swBomFeature.Configuration = Configuration                      'Set BOM Configuration
                  Exit For
              ElseIf count = ConfigurationCount - 1 Then                          'If the configuration is not available then
                  MsgBox "Cannot change configuration of " & DrawingViewName & " because configuration " & Configuration & _
                  " was not available.", vbOKOnly, "ChangeDrawingView function call could not change Configuration"
              End If                                                              'send the user a message.
          Next count
      Else        'If anything other than a drawing view or BOM is
          MsgBox "Error Changing: " & DrawingViewName, vbOKOnly, "Object Type not supported by ChangeDrawingView function" & _
                 " call.  Only Drawing Views and BOM Tables are supported."
      End If        'passed to the function call then do nothing.
      Set swDrawingDoc = Nothing
      Set swSheet = Nothing
      Set swView = Nothing
      Set swConfigMgr = Nothing
      Set swConfiguration = Nothing
      Set swBomFeature = Nothing
      Set swBomTableAnnotation = Nothing
      Set swTableAnnotation = Nothing
      Set swAnn = Nothing
      Set swSelMgr = Nothing
