Deafault K factor changing
Question asked by Piotr Tetlak on Aug 19, 2016
Latest reply on Aug 19, 2016 by Piotr Tetlak
Hello!
I know that similar topic already have been discussed on that forum. Unfortunately I didn't find clear answer how to change default K-factor in SheetMetal part.
Could somebody explain me why example below doesn't work properly:
Option Explicit
    Dim swApp                             As SldWorks.SldWorks
    Dim swModel                           As SldWorks.ModelDoc2
     Dim swFeat                            As SldWorks.Feature
    Dim swBaseFlange                 As SldWorks.BaseFlangeFeatureData
    Dim swSheetMetal                 As SldWorks.SheetMetalFeatureData
    Set swModel = swApp.ActiveDoc
    Set swFeat = swModel.FirstFeature
      Do While Not swFeat Is Nothing
        If swFeat.GetTypeName = "SheetMetal" Then
                  Set swSheetMetal = swFeat.GetDefinition
                  swSheetMetal.AccessSelections swModel, Nothing
                  swSheetMetal.BendAllowanceType = 2
                  swSheetMetal.Kfactor = 0.2
                  swFeat.ModifyDefinition swSheetMetal, swModel, Nothing
    Set swFeat = swFeat.GetNextFeature
    Loop
    swModel.ForceRebuild3 False
    swModel.Save
The K-factor value is changed in model but I have to click "Override default value" in sheet menu. That is very unacceptable for me.
I would really appreciate if smb could explain me how to change Default K-factor value.
After some time I've found out that I need to edit kfactor of SheetMetalTemplate, not particular SheetMetal.
Using loop:
I am not able to get SheetMetalTemplate object.
Does anyone have any idea how to get it?
Wiadomość była edytowana przez: Piotr Tetlak
