Hi
One of our users moved a file that was checked into a folder with workflow A.
The user then checked out the file and moved the file to another folder with workflow B.
He now has errors trying to check in, as the new folder has a different workflow.
Can anyone tell me what the process is for moving files into another folder with a different workflow?
Do I have to create a transition in workflow A to allow the file move to workflow B?
What is the best way of doing this?
You can create a transition from the state the file is currently in to the state in the original workflow where it should be. Once the file is transitioned you can delete the transition.
