I have a macro that can capture all bounding box dimensions and displays them in ascending order in custom properties. I started to use TASK and now i can run a macro on many parts without to manual open them and run macro.
Problem is that i work with sheet metal parts and that macro does not flatten sheet metal parts before it takes dimensions.
Does someone know how to modify that macro to check a part configuration and if it if a sheet metal first to flatten it and then to take dimensions.
MACRO:
Dim Part As SldWorks.ModelDoc2
Dim Height As Variant
Dim Width As Variant
Dim Length As Variant
Dim Corners As Variant
Dim retval As Boolean
Dim UserUnits As Variant
Const swDocPart = 1
Const swDocASSEMBLY = 2
'Enum swLengthUnit_e
Const swMM = 0
Const swCM = 1
Const swMETER = 2
Const swINCHES = 3
Const swFEET = 4
Const swFEETINCHES = 5
Const swANGSTROM = 6
Const swNANOMETER = 7
Const swMICRON = 8
Const swMIL = 9
Const swUIN = 10
'Enum swFractionDisplay_e
Const swNONE = 0
Const swDECIMAL = 1
Const swFRACTION = 2
Dim swCustPropMgr As SldWorks.CustomPropertyManager
Dim StockSize As String
Function DecimalToFeetInches(DecimalLength As Variant, Denominator As Integer) As String
' converts decimal inches to feet/inches/fractions
Dim intFeet As Integer
Dim intInches As Integer
Dim intFractions As Integer
Dim FractToDecimal As Double
Dim remainder As Double
Dim tmpVal As Double
' compute whole feet
intFeet = Int(DecimalLength / 12)
remainder = DecimalLength - (intFeet * 12)
tmpVal = CDbl(Denominator)
intInches = Int(remainder)
remainder = remainder - intInches
If Not (remainder = 0) Then
If Not (Denominator = 0) Then
FractToDecimal = 1 / tmpVal
If FractToDecimal > 0 Then
intFractions = Int(remainder / FractToDecimal)
If (remainder / FractToDecimal) - intFractions > 0 Then
intFractions = intFractions + 1
Call FractUp(intFeet, intInches, intFractions, Denominator) ' Simplify up & down
DecimalToFeetInches = LTrim$(Str$(intFeet)) & "'-"
DecimalToFeetInches = DecimalToFeetInches & LTrim$(Str$(intInches))
If intFractions > 0 Then
DecimalToFeetInches = DecimalToFeetInches & " "
DecimalToFeetInches = DecimalToFeetInches & LTrim$(Str$(intFractions))
DecimalToFeetInches = DecimalToFeetInches & "/" & LTrim$(Str$(Denominator))
DecimalToFeetInches = DecimalToFeetInches & Chr$(34)
End Function
Function FractUp(InputFt As Integer, InputInch As Integer, InputNum As Integer, InputDenom As Integer)
While InputNum Mod 2 = 0 And InputDenom Mod 2 = 0
InputNum = InputNum / 2
InputDenom = InputDenom / 2
Wend
If InputDenom = 1 Then ' Full inch
InputInch = InputInch + 1
InputNum = 0
If InputInch = 12 Then ' Full foot
InputFt = InputFt + 1
InputInch = 0
End Function
Sub SortDimensions()
Dim arr(1 To 3) As Double
arr(1) = Length
arr(2) = Width
arr(3) = Height
SortArr arr
Sub SortArr(arr() As Double)
Dim i As Long
Dim j As Long
Dim tmp As String
Dim p As String
For i = LBound(arr) To UBound(arr) - 1
For j = i + 1 To UBound(arr)
If arr(i) > arr(j) Then
tmp = arr(i)
arr(i) = arr(j)
arr(j) = tmp
Next j
Next i
Dimenzije = (arr(1) & "x" & arr(2) & "x" & arr(3))
Set swCustProp = Part.Extension.CustomPropertyManager("")
retval = Part.DeleteCustomInfo2("", "Dimenzije") 'Remove existing properties
swCustProp.Add3 "Dimenzije", swCustomInfoText, Dimenzije, 1 'Add latest values
Sub Main()
Set Part = swApp.ActiveDoc
If Part Is Nothing Then ' Did we get anything?
MsgBox "You need to have a part or assy open at this point." & Chr$(13) & Chr$(10) _
& Chr$(10) & "Open one and try again."
Exit Sub
If (Part.GetType = swDocPart) Then
Corners = Part.GetPartBox(True) ' True comes back as system units - meters
ElseIf Part.GetType = swDocASSEMBLY Then ' Units will come back as meters
Corners = Part.GetBox(0)
Else
MsgBox "This macro is only useful with a part or assy." & Chr$(13) & Chr$(10) & "Open one of those and try again."
Exit Sub
UserUnits = Part.GetUnits()
Select Case Part.GetUnits(0)
Case swMM
ConvFactor = 1 * 1000
Case swCM
Case swMETER
ConvFactor = 1
Case swINCHES
ConvFactor = 1 / 0.0254
Case swFEET
ConvFactor = 1 / (0.0254 * 12)
Case swFEETINCHES
ConvFactor = 1 / 0.0254 ' Pass inches through
Case swANGSTROM
ConvFactor = 10000000000#
Case swNANOMETER
Case swMICRON
Case swMIL
ConvFactor = (1 / 0.0254) * 1000
Case swUIN
ConvFactor = (1 / 0.0254) * 1000000
End Select
Height = Round((Abs(Corners(4) - Corners(1)) * ConvFactor), UserUnits(3)) ' Z axis
Width = Round((Abs(Corners(5) - Corners(2)) * ConvFactor), UserUnits(3)) ' Y axis
Length = Round((Abs(Corners(3) - Corners(0)) * ConvFactor), UserUnits(3)) ' X axis
' Check for either (Feet-Inches OR Inches) AND fractions. If so, return Ft-In
If (UserUnits(0) = 5 Or UserUnits(0) = 3) And UserUnits(1) = 2 Then
Height = DecimalToFeetInches(Height, Val(UserUnits(2)))
Width = DecimalToFeetInches(Width, Val(UserUnits(2)))
Length = DecimalToFeetInches(Length, Val(UserUnits(2)))
Call SortDimensions
Nice day
Antonio
You can use codes from this example: Flatten Sheet Metal Part Example (VBA)
