5 Replies Latest reply on Aug 19, 2016 11:12 AM by Dan Hofstetter
    Script to change model based on Excel file
    Dan Hofstetter
      I have been having trouble with "Server Busy" errors in SolidWorks 2013 when opening a .SLDPRT file that has a slot feature that is LPatterned many times (300 or more small slots in one part).  The dimensions of the slot and number of instances are defined in a Design Table file.  I have not been able to prevent the "Server Busy" warning, and it won't go away on its own no matter how long I wait.  I am automating SolidWorks from an Excel macro, and am not always at my desk to click the "Retry" button every time this occurs, so I am looking for a workaround.
      I think one way to avoid the Server Busy error is to delete the design table from the .SLDPRT file, then change the dimensions and suppression states of all design table variables using VBA code (pushing the dimension values via the API).  My thought was to go through the Excel design table file one column at a time, read the variable name, decide if it is a dimension or state, then change the dimension or state based on the entered value in the next row.
      I got the following code snippet to work:
      Sub Change_SW_Dims()
          Set Part = swApp.ActiveDoc
          Part.Parameter("TankDX@Tank Profile Plan View").SystemValue = 1600 * 0.0254
          boolstatus = Part.Extension.SelectByID2("Slot 1", "BODYFEATURE", 0, 0, 0, False, 0, Nothing, 0)
          Part.EditUnsuppress2
          Part.EditRebuild
          Part.ClearSelection
      Before spending a lot of time playing around with this, I thought I'd search for something similar that I could modify.  I have not been able to find similar code yet, and was wondering if anyone might be able to point me in the right direction?
        • Re: Script to change model based on Excel file
          Dan Hofstetter
          Ok, I got this working, here is the code in case anyone else ever needs to do something similar.  I don't see an option to include this as anything other than plain text, sorry:
          'First read all values from DesignTable.xlsx
          'into a two-dimensional array
              Dim xlApp As Excel.Application
              Dim wb As Workbook
              Set xlApp = CreateObject("Excel.Application")
              xlApp.Visible = True 'For troubleshooting so the window appears
              xlApp.Workbooks.Open ("F:\TEMP\DesignTable.xlsx")
              Set wb = xlApp.Workbooks(1)
              wb.Worksheets(1).Activate 'Activates the first sheet in workbook regardless of name
              Dim varArray() As Variant
              Dim rngSource As Range
              Dim nRows, nCols As Integer
              Set rngSource = wb.Worksheets(1).Range("B2:JB3")
              nRows = rngSource.Rows.Count
              nCols = rngSource.Columns.Count
              ReDim varArray(1 To rngSource.Rows.Count, 1 To rngSource.Columns.Count)
              varArray = rngSource.Value
              Debug.Print ("Rows = " & rngSource.Rows.Count)
              Debug.Print ("Cols = " & rngSource.Columns.Count)
              For i = 1 To rngSource.Columns.Count
                  Debug.Print (varArray(1, i) & " = " & varArray(2, i))
              Next i
              xlApp.Workbooks("DesignTable.xlsx").Close
              xlApp.Quit
          'Next change dimension values and suppression states in SolidWorks
              For i = 1 To nCols
                  If Left(varArray(1, i), 1) <> "$" Then
                      'Debug.Print ("Not a state")
                      Debug.Print (i & ": " & varArray(1, i) & " = " & varArray(2, i))
                      Part.Parameter(varArray(1, i)).SystemValue = varArray(2, i) * 0.0254
                  Else
                      boolstatus = Part.Extension.SelectByID2(varArray(1, i), "BODYFEATURE", 0, 0, 0, False, 0, Nothing, 0)
                      If (varArray(2, i) = "Suppressed") Then
                          Part.EditSuppress2
                      Else
                          If (varArray(2, i) = "Unsuppressed") Then
              Next i
              Part.EditRebuild
              Part.ClearSelection
              Deepak Gupta
              You can always attach files here.
              Check #18 of Forum Posting on how to attach files while replying to a post.
                  Dan Hofstetter
                  Thanks for the tip!  In general when searching for help with code I look for snippets in help forums first, where copy and paste is easy and doesn't require me to download anything.  I don't use this forum much and couldn't remember if you had requirements for pasting code snippets - some of the other programming forum moderators get upset if you don't post them in a quote block.  Cheers!
                      Deepak Gupta
                      No you're free to paste them or upload.
                      You may format them if required like this.
                          For i = 1 To nCols
                              Else
                                      Part.EditSuppress2
                                  Else
                          Next i
                          Part.EditRebuild
                          Part.ClearSelection
                      This is available in advanced editor only. Click on reply and then click on "use advanced editor" on right side
                      And then format as required
