3 Replies Latest reply on Aug 19, 2016 2:44 PM by Keith Rice
    Change custom property on referenced drawings
    Luke Frost
      Good Afternoon All,
      Being a complete API novice I have been looking for a macro that will go through an assembly and change specific custom properties for the sub assemblies and haven't managed to find anything at all that is related.  I have however managed to put something together based on several different things that i have found which isn't completely air tight however it seems to run ok even if some times it does delete the variables ad not create them if the instances are met initially.  Haven't been able to figure out how to achieve this.
      The thing however that i am struggling with it is to change custom properties on referenced drawings that are for either the top level assembly or any of the drawings for the parts that are in the assembly.
      The current code is as follows:
      Option Explicit
      Dim swModel As ModelDoc2
      Dim vComps As Variant
      Dim i As Integer
      Set swModel = swApp.ActiveDoc
      Dim strDesToReplace As String
      Dim strDesReplacing As String
      Dim strNoToReplace As String
      Dim strNoReplacing As String
      strDesToReplace = InputBox("Please enter the text that you wish to find within the Description Custom Property", "Enter Search String")
      strDesReplacing = InputBox("Please enter the text that you wish to replace the previously entered string in the Description Custom Property", "Enter Replacing String")
      strNoToReplace = InputBox("Please enter the text that you wish to find within the Part Number Custom Property", "Enter Search String")
      strNoReplacing = InputBox("Please enter the text that you wish to replace the previously entered string in the Part Number Custom Property", "Enter Replacing String")
      If strDesToReplace = "" Or strDesReplacing = "" Or strNoToReplace = "" Or strNoReplacing = "" Then
          Exit Sub
      Else
          ChangeValues swModel, strDesToReplace, strDesReplacing, strNoToReplace, strNoReplacing
          If swModel.GetType = swDocASSEMBLY Then
              Set swAssy = swModel
              vComps = swAssy.GetComponents(False)
              For i = 0 To UBound(vComps)
                  Set swComp = vComps(i)
                  Set swModel = swComp.GetModelDoc2
                  'updateProperty swModel
              Next i
          MsgBox "All Custom Properties have been successfully changed", vbInformation + vbOK, "Find & Replace Complete"
      Function ChangeValues(swModel As SldWorks.ModelDoc2, strDesToReplace As String, strDesReplaceWith As String, strNoToReplace As String, strNoReplaceWith As String) As Boolean
      Dim cpm As CustomPropertyManager
      Dim names As Variant
      Dim name As Variant
      Dim textexp As String
      Dim evalval As String
      Dim strNumber As String
      Dim strDescription As String
      Dim strdrw_no As String
      Set cpm = swModel.Extension.CustomPropertyManager("")
      names = cpm.GetNames
      For Each name In names
          cpm.Get2 name, textexp, evalval
          Debug.Print name & " = " & evalval
          If name = "Description" Then
              If evalval <> "" Then
                  strDescription = Replace(evalval, strDesToReplace, strDesReplaceWith)
                  cpm.Delete "Description"
                  cpm.Add2 "Description", swCustomInfoText, strDescription
      Next name
          If name = "Number" Then
                  strNumber = Replace(evalval, strNoToReplace, strNoReplaceWith)
                  cpm.Delete "Number"
                  cpm.Add2 "Number", swCustomInfoText, strNumber
      Next name
          If name = "drw_no" Then
                  strdrw_no = Replace(evalval, strNoToReplace, strNoReplaceWith)
                  cpm.Delete "drw_no"
                  cpm.Add2 "drw_no", swCustomInfoText, strdrw_no
      Next name
      End Function
      Can anyone please assist me with this.
      Thanks in advanced
      Frosty
        • Re: Change custom property on referenced drawings
          John Stoltzfus
          Should be much easier to use Task Scheduler if your just replacing or changing Custom Properties
              Luke Frost
              Hi John,
              Thanks for the reply however unfortunately i am unable to use Task Scheduler due to the fact that i need to use a find and replace type operation to replace a small part of a variable that changes with every part. I did initially try going down this route however it doesn't allow you to do a find and replace operation just a static string.
              Frosty
              Keith Rice
              In our Macro Library we have a macro called "Run code on every part in assembly" that contains sample code on how to modify the custom properties of every part in an assembly. You can modify it to work on all sub-assemblies as well by just removing the conditional statement that tests if the component is a part.
              Unless you know exactly what the names or locations of these drawings are, you would have to used the Document Manager API to get the "Where Used" paths for the models used to create drawings. See ISwDMDocument::WhereUsed in particular.
              As an example of the first case, if you know that there will always be a drawing with the same name as the assembly in the same folder as that assembly, then you should be able to just get the path of the assembly, replace the last six characters with SLDDRW, and then open the document at that path and do what you need to do.
              Keith
              SolidWorks API Developer
