I have a simple part attached, when I extrude my sketch using "up to next" from a plane, inside the solid (i.e. intersects the solid), it extrudes properly to all the faces in its path and not ignores them, however when I extrude the sketch from some plane outside of the solid, SW ignores all the faces in its path except the one on the back.
I know it's not a bug, and it has something to do with how "up to next" works, but I can't think of any good explanation that convince me. So my problem is not modeling it the way I want, just want to know what exactly is the reason for this.
Vahid,
lol - learned something new today -
You need to select up to surface first as Up To Next isn't in the dialog box
and only after you edit the Extrude Feature does the Up To Next show - and that gives you two different results
