1 Reply Latest reply on Aug 17, 2016 3:47 PM by Keith Rice
    how to judge the edge is model line or silhouette edges  in drawing
    xianbin Huang
      Hi All
            I write a code to dimension the arc in all views of drawings
      Now , I use the code    vEdges = swView.GetPolylines7(1, vPolyLinesBuffer) to get the edges and data
      How to know the edges is model line or silhouette edges?
      if  it is Silhouette edges ,how to select it by API
        • Re: how to judge the edge is model line or silhouette edges  in drawing
          Keith Rice
          Bin,
          Select a drawing view and run this code. All silhouette edges in that view will be selected.
          Dim swView As SldWorks.View
          Dim swSilEdge As SldWorks.SilhouetteEdge
          Dim vEdges As Variant
          Dim i As Integer
              Set swModel = swApp.ActiveDoc
              Set swView = swSelMgr.GetSelectedObject6(1, -1)
              swModel.ClearSelection2 True
              vEdges = swView.GetPolylines7(1, Empty)
              If IsEmpty(vEdges) Then Exit Sub
              For i = 0 To UBound(vEdges)
                  If Not vEdges(i) Is Nothing Then
                      If TypeOf vEdges(i) Is SldWorks.SilhouetteEdge Then
                          Set swSilEdge = vEdges(i)
                          swSilEdge.Select2 True, Nothing
              Next i
          Keith
          SolidWorks API Automation Services
