I have a multi level assembly with base feature being a multi body part (I create the multibody part, then add various items at different assembly levels). I am having difficulty getting display states/configurations set up to show the items I want at the top level.
My model is an architectural structure. The multibody part is the "structure" with all the walls including studs ( I am hoping to make this to be a template for all my future structures as they are all relatively the same). In the next level I add the doors and windows and do the cuts to remove the studs I do not require. I then create a top level where I add all the finishing item (toilets, sinks, etc).
In the top level I want to have 2 display states/configurations; 1 to show with all the studs, and one to show with the studs removed.
I can set the display states in the base structure to show how I want, but once i go into the next levels, and create a confuguration or display state I can't get the same result. If I create a configuration and set it to the 'no studs' display state, that changes in all configurations. What ever I show/hide in the solid bodies folder changes in all the display states/configurations.
Is is possible to do what I need with a multibody part? Am I doing something wrong?
I have done this same thing using a weldment as my base part( because I think that a weldment is a better option than a multibody part), but unfortunately I had issues with the display style in my drawings (several of my views would disapper unless I set them to a shaded style) so it was not feasible to use.
Thanks for any input!
Colleen,
When you go up to the higher level, are you setting the sub-component display state per the upper level display state? In the assembly you can right click on the component and go to Component Properties to select the Display State and there's an option to change it for "This Display State", "All Display States", or "Select Display States". You can then setup your assembly display states and have the part display state change in the assembly display states.
Best regards,
Fred
