Step 1: I create a export rule "Item Export Rule"
Step 2: Add an action to transition
Step 3: Change state the item to create xml file but there is no xml file in the Output XML-files folder
What's wrong with my configuration? Pls help me.
Everything is written in the help document. but it's not working
Please help me solve this problem, at least tell me where the error report at.
Hi Tran, are you using 2016 Sp4 by any chance? There is a known issue where BOM data export to XML is not working.
Kind regards
Prasad
Hi Prasad
Thanks for reply. I have upgraded to 2016 sp4 already but it's still not working.
Hi Tran, sorry perhaps I was not clear. The issue is with using 2016 SP4.
I would speak to your VAR as they probably have a workaround from SolidWorks.
There's actually a hot fix for this now - S-071775. Check with VAR if you can't access it.
Hello Steve, and thank you for this.
Tran, please look at the KB solution provided by Steve, there is a hotfix made available.
Kind regards,
Its work fine now. Thanks for answers very quickly
