When making measurements it is very helpful to draw a line between the two selected points or between the measured results. These lines are important to provide verification that the measured results are correct.
The API measure command is a good command but it is surprising that the command doesn't also provide the lines as shown below:
I have looked but have not been able to find an option for this.
The nest best approach is to use the selection points draw our own lines. Is there a command set to do this?
The measure command returns an X, Y, Z values and DeltaX, DeltaY, DeltaZ (the measured results). I have made a number of attempts to use these values to draw these "reference" lines within both assembly and part model spaces without success. Is there a way to "translate" these values into something useful?
SolidWorks API calls are not designed to mimic the GUI, only to perform the "end" task. In the case of the measure tool, the end task is simply to obtain a measurement.
If you want to create any custom graphics on the screen then you will need to insert those graphics "directly" using OpenGL (not a trivial task, unfortunately). There are no API calls that will assist you here.
Keith
SolidWorks API Tutorials
