Below are the sketches of the logo that I want to emboss. These are 4 different sketches that
I'm wrapping onto the cylinder. The big number 9 is one sketch, the grid is another sketch, the text "SQUARE" is another, and the text "IN THE AIR with trademark" are the 4th sketch. The big number "9" i'm trying to deboss to a depth of .03 inches. All the
other sketches I'm debossing to a depth of .06 inches.
Here's what I'm getting when I do this. The grid and the big number "9" aren't quite right. It ends up making them both the same depth, .06 inches, even though the emboss for the "9" is set at .03 inches.
Here's a different molded part that has the logo debossed the way I want. Trying to achieve this with wrap on the cylindrical surface above. Would appreciate any thought on how to fix this. Maybe there's a different approach to use? I tried combining sketches into 1 and doing this, but the "9" and the grid don't play well together. You get open contours or overlapping contours, etc..
Excellent work John.. You did it all. All I had to do was > edit Surface-Offset2 > clear the selection (Wrap2) > right click near the 9 and select other - you should get the option for Face@Wrap2 - pick that and the 9 should highlight.
Then hide Surface-Offset1. You can do that right from the feature manager tree. Now your done. You did all the work just picked the wrong surface. It really was that simple. Once again,, great job.
I attached a parasolid so you can see what my model looks like. You should do a shaded with edges on it.
I would advise you to save your model with a different name (and work with that) just in case you need to go back to the original.
Edit I noticed that there is a sliver of material near the bottom of the 9 and your grid. It is hard to see. You probably should edit your grid or your 9 a tad to take care of that.
