Hello!
Who know what greel L symbol means on sketches or elements ib lip feat parts?? how to put it or delete it?
Thanks.
Hello!
Thanks.
The L tells SolidWorks and the user that the feature is a library feature. It is needed in order for SolidWorks to process the library feature correctly. After the library feature is added, you should be able to right click and select dissolve library feature
Thank you very much. Somehow, later I accidentally put and library line and finally got it.
But I have another problem. Probably you could help me?
I don't have the window on the left. It usually pops out when you click on measurement, for instance.
I suppose I could accidentally switch it off...or it is some error in programme happened?)
Make sure the box below is checked. (I had the same problem a few years ago: PropertyManager lost when sketching.)
