Hi!
I am having troubles with the motion analysis of a 4wheeled device. I put a rotary motor on one of the wheels (all the wheels are solidary with each other). But it seems I cannot make it right, I don't know what I am doing wrong.
Also, I wanted to know if it is possible in this analysis to evaluate the velocities, accelerations as a force is applied to the device (in a way it can be seen in the figure in attachment). Or, as well, the stress in the material through the movement of the device.
The device was made in SW 2016, SP0. I put it attached.
Thanks for all the help!
Hi Joana,
I was able to make a simulation out of your model. You had several mating issues that I corrected as you can see in the file.
I did add a motor and the forces as you were looking to. Please make sure the parameters in your simulations are correct, I did not spend enough time in actually setting the simulation for real results. I only wanted to make sure you could simulate the assy.
Let me know
Gianluca
