Tried to change Cross Reference Type on a miscellaneous.
Now symbols began to be imposed:
Hyperlink to project:
Hello Igor
It looks like that your cross reference config file is wrong or damaged. Go to the "Project" tab -> Configuration -> Cross references. On the right hand side, you see your actually used config file. If I try to open its properties, Electrical crashes. I deleted it and opened the scheme side. It looks like expected.
Hi Igor
I think that the source of your behavior is in conjunction to the option "cross reference type" into the symbol properties. With symbol properties, I mean the properties of the contacts and not the relay symbol properties. If you need the information into the cross reference table, the contacts has to be defined as "child".
Wrong settings:
Appropriate settings:
