My program needs the capability to measure the shortest distance between the surface of two holes. Below are a number of cases that all work but there is one left:
For the cases of measuring the distance between two vertices the results are good (shown below).
(code to get first vertex)
vertex = SelObj.GetPoint
bRet = TransPoint(vertex(0), vertex(1), vertex(2))
P1x = T1x
P1y = T1y
P1z = T1z
(code to get second vertex)
P2x = T1x
P2y = T1y
P2z = T1z
Calls Calcdist which translates the coordinates (only in the case of an assembly) and displays the values.
calls tmpline.
(tmpline Sub):
swModel.SetAddToDB(True)
swModel.Insert3DSketch2(False)
swSkPoint1 = swModel.CreatePoint2(P1x, P1y, P1z)
swSkPoint2 = swModel.CreatePoint2(P2x, P2y, P2z)
swSkLine = swModel.CreateLine2(P1x, P1y, P1z, P2x, P2y, P2z)
swModel.SetAddToDB(False)
TempSketch = swModel.GetActiveSketch2
swFeat = TempSketch
swFeat.Name = "DispMeaSketch"
swModel.Insert3DSketch2(True)
bRet = swModel.EditRebuild3
(End Sub)
The results worked very nicely for "parts" but for "assemblies" the points needed to be translated between the part and the assembly coordinate systems:
The next case is to calculate the distance between two surface within an assembly. The following code was used:
(code to get first and second surfaces)
nDist = swModel.ClosestDistance(swFace1, swFace2, vPoint1, vPoint2)
P1x = vPoint1(0)
P1y = vPoint1(1)
P1z = vPoint1(2)
P2x = vPoint2(0)
P2y = vPoint2(1)
P2z = vPoint2(2)
(Call Calcdist which automatically "translates" the points to the assembly Coordinate system and displays the values as shown below)
The same results work for both "parts" and for "assemblies". The only difference is that the points need to be translated for assemblies.
The problem is that when the two cylindrical surfaces are parallel the result is not the shortest distance but rather between the two center lines:
According to the literature, to resolve this issue with two parallel cylinders the following code was added:
nDist = swModel.ClosestDistance(swFace1, swFace2, vPoint1, vPoint2) 'Gets Center Point
If swSurf1.IsCylinder Then 'Measure has returned the center point, so use the point on the other surface
vClosestPt1 = swFace1.GetClosestPointOn(vPoint2(0), vPoint2(1), vPoint2(2)) 'Fails here in assembly
Else 'Probably on the surface, but just to be sure...
vClosestPt1 = swFace1.GetClosestPointOn(vPoint1(0), vPoint1(1), vPoint1(2))
If swSurf2.IsCylinder Then 'Measure has returned the center point, so use the point on the other surface
vClosestPt2 = swFace2.GetClosestPointOn(vPoint1(0), vPoint1(1), vPoint1(2))
vClosestPt2 = swFace2.GetClosestPointOn(vPoint2(0), vPoint2(1), vPoint2(2))
P1x = vClosestPt1(0)
P1y = vClosestPt1(1)
P1z = vClosestPt1(2)
P2x = vClosestPt2(0)
P2y = vClosestPt2(1)
P2z = vClosestPt2(2)
(Calls Calcdist and displays the values)
(calls tmpline which also translates the the points for the Assembly coordinate system):
Within a "part" file the results are good:
However within an "assembly" the results are wrong (shown below). All of the code that is working in the previous examples is the same. Below is the result when the points are translated. Sadly, the results are not much better if the end points of the temporary line are translated or not.
It is expected that for a part, the result should be good without translation and for an assembly the result should be good with translation. However, in this one case, neither result is good.
Any idea what the problem is? One possibility is that perhaps the GetClosestPointOn returns the point values that are already in the Assembly Coordinate system?
Has anyone else ran into this? Is this a problem within the API? Any ideas about how to correct this last case?
Hi Edwin
You are right for assemblies the transformation is required:
Set swCompXform = swComp.Transform2
Set swMathPt = swMathPt.MultiplyTransform(swCompXform)
Method: "swFace2.GetClosestPointOn" Is quite precise and never failed me
