I have the following question.
For example, I have a frequency converter which has a set of inputs - analog, discrete, etc. In one cases I can use one set of inputs, in others - another.
It would be convenient to me to create a component with a totality of inputs, and then to use only necessary in a Black Box symbol.
But now, there is a replacement of numbers in a symbol. There is an initial symbol:
Here after application:
Whether it is possible to make that the numbers entered by me remained?
P.S. I saw that in the table Circuits it is possible to move elements, but it is not really convenient.
Those labels are driven in the following way:
1. When you place a connection point into a symbol, it gets a label: "#P_TAG_1" for example.
2. If you drop that symbol with no manufacturer part associated, these tags should be blank.
3. When you associate a manufacturer part, it will pull information from that part to add the labels. This information is located in the "Circuits, terminals" tab of the manufacturer part properties. The "Terminal Marks" column is what determines how the terminals will be labeled.
If your terminal labels are not consistent with what is in the manufacturer part data, then there may be some issue with the tags you are using. If the tags are not blank when no manufacturer part is associated, then there may be some issue with the tags you are using.
Also, ensure you do not have multiple manufacturer parts associated.
If you are still having problems, send me a copy of this screenshot for the component you are working with:
The bottom window should show all green icons. Blue/Red icons mean there are un-associated connection points. This list here will determine which circuits from the manufacturer part get applied to which circuits on the symbol. You can drag/drop to change circuit associations from this screen.
