I have an assembly drawing BOM (standard) showing accurate part counts for parts I modeled. I am also using parts (fasteners) imported from McMaster-Carr. The qnty column shows accurate numbers for some of the McMstr fasteners although others have 5-6 digit numbers of which I can not determine their source. In some cases the incorrect numbers are the same for different fasteners. Ex: If you look at the attached, items #14 and 18 show the same numbers (545010). In reality though there are only 8 of each in the assembly. There is a correlation between the two part, that is that they are attach to one another- not sure if that has anything to do with the issue...
Any assist will be greatly appreciated. Thank you.
Without having your entire assembly (sldprt's and sldasm) it will be hard to troubleshoot the problem.
