When I open a .dwg that was created in SolidWorks in E-Drawings everything looks fine. However when I go to print in normal mode I lose most of the color even though all the settings are set to be in color, in Draft all color returns.. This happens in some but not all drawings. I went in and verified that the printer settings are defaulted to print in color, also the checkbox on the print dialog in E-Drawings is also checked for color. Even in the print preview pane, when you select draft all colors show, when you click normal you lose most color. Has anyone else seen this issue? Or know how to correct it?
