I made a copy of solidworks Gauge Table (BA) and entered new values for 16GA steel with new 0.125" Radius and 0.0625" Radius. Saved it.
when I use this table to make a base flange , browse to the table , I could see all Radius in drop down list except 0.0625" (this I entered in new column, whereas 0.125" radius , I changed in first column where it was 0.25") , any way I selected 0.125" radius to see if it works and click ok .
I got the message - "Bend Table is Invalid" . I have attached the Table for ready ref. Please let me know what I am doing wrong. Why I can see 0.125" radius and not the 0.0625" radius. and why the "bend table is invalid"
I think the empty columns F and G are the problem, try removing them. Automated tools usually stop reading a file when an empty cell/row/column is reached.
If that doesn't work, try sorting the columns by bending radius, so R 0,063" to column B and 1/8" to column C and so on. You can also try to have only a single radius on each column, I believe I heard problems might arise if you have multiple radii in one column.
