Just to be clear, I'm talking about templates in the PDMWE
Administration tool used to create projects, folders, etc. not
SolidWorks template files. On advice from our VAR we added a prefix
to our variables. I want to get rid of the prefix, but when I
rename a variable it screws up the template that uses it.
Yup, I'm still with you. The variables used in PDMWE
templates are called template variables. Very often putting a
prefix in front of their names is a good thing to keep them from
being confused with regular variables.
I have renamed template variables before, I can't imagine what
would be screwing your up. Keep your eye open, there are many
little nooks and crannies that template variable could be used in
step 4 of the template editor. Perhaps you missed one?
If the template variable is coming from a Template Input Form (step
3 in the wizard), make sure the card variable is mapped to the
renamed template variable.
Also, it is good practice to prefix template variables (I use t_ )
so as not to confuse template variables with card variables. This
is something I teach all VARs.
I've done that as well. After I renamed 'ABC_Product' to 'Product'.
I replaced it in the template input form and mapped the renamed
card variable to the template variable. However, I see
'ABC_Product' with a red circle with a white x in the card variable
list in step 3 of the wizard.
When I use the template I get a message- The variable
'ABC_Product', which is used by the template, does not exist in the
vault. Please add a variable with this name using the card editor.
It's as if the card variable is still attached to the input card
even though I removed (renamed) it.
Without seeing your exact setup, it's difficult to say where
exactly the problem is... Another place to check is in Step 4 of
the wizard. Ar you copying the variables to the resulting file data
card? You must look eveywhere it is being used and fix it. If it
takes too lond, then it may be faster to just re-create the
template.
I created a new variable, input card and template to test this out.
I was able to rename the variable. I'll get our VAR to help me
determine why this won't work with our existing templates.
My VAR found the problem in my existing templates. I hadn't
gone through the folders in the template and cleared out the
variable references under properties. Oh well, another entry for my
"PDMWorks for Dummies" book (with me as the dummy!).
