CMCleon Martin17/09/2008
I am new to vb so bare with me. I am trying to make my macro so that it has a 15 day trial period , that after it has been run once that it cannot after 15 days later. I have code that works
If Date > #9/18/2008# Then
MsgBox "Your trial period has ended"
End
only thing is it leaves no log on the computer as to when it was first run and does not set the date accordingly.
I found this code on a site and the code is for an excel sheet could somebody make it so it would work for a Sw macro?
Dim swApp As Object
Option Explicit
Private Sub Workbook_Open()
Dim StartTime#, CurrentTime#
'SET YOUR OWN TRIAL PERIOD BELOW
'Integers (1, 2, 3,...etc) = number of days use
'1/24 = 1Hr, 1/48 = 30Mins, 1/144 = 10Mins use
Const TrialPeriod# = 30 '< 30 days trial
'set your own obscure path and file-name
Const ObscurePath$ = "C:\"
Const ObscureFile$ = "TestFileLog.Log"
If Dir(ObscurePath & ObscureFile) = Empty Then
StartTime = Format(Now, "#0.#########0")
Open ObscurePath & ObscureFile For Output As #1
Print #1, StartTime
Else
Open ObscurePath & ObscureFile For Input As #1
Input #1, StartTime
CurrentTime = Format(Now, "#0.#########0")
If CurrentTime < StartTime + TrialPeriod Then
Close #1
Exit Sub
Else
If [A1] <> "Expired" Then
MsgBox "Sorry, your trial period has expired - your data" & vbLf & _
"will now be extracted and saved for you..." & vbLf & _
"" & vbLf & _
"This workbook will then be made unusable."
Close #1
SaveShtsAsBook
[A1] = "Expired"
ActiveWorkbook.Save
Application.Quit
ElseIf [A1] = "Expired" Then
Close #1
Application.Quit
Close #1
Sub SaveShtsAsBook()
Dim Sheet As Worksheet, SheetName$, MyFilePath$, N&
MyFilePath$ = ActiveWorkbook.Path & "\" & _
Left(ThisWorkbook.Name, Len(ThisWorkbook.Name) - 4)
With Application
.ScreenUpdating = False
.DisplayAlerts = False
On Error Resume Next '<< a folder exists
MkDir MyFilePath '<< create a folder
For N = 1 To Sheets.Count
Sheets(N).Activate
SheetName = ActiveSheet.Name
Cells.Copy
Workbooks.Add (xlWBATWorksheet)
With ActiveWorkbook
With .ActiveSheet
.Paste
'//N.B. to remove all the cell formulas,
'//uncomment the 4 lines of code below...
'With Cells
'.Copy
'.PasteSpecial Paste:=xlPasteValues
'End With
.Name = SheetName
[A1].Select
End With
'save book in this folder
.SaveAs FileName:=MyFilePath _
& "\" & SheetName & ".xls"
.Close SaveChanges:=True
End With
.CutCopyMode = False
Next
End With
Open MyFilePath & "\READ ME.log" For Output As #1
Print #1, "Thank you for trying out this product."
Print #1, "If it meets your requirements, visit"
Print #1, " http://www.xxxxx/xxxx to purchase"
Print #1, "the full (unrestricted) version..."
Close #1
Sorry for the long post !!
Any suggestions or replies ? Thanks a Million
