Hi All,
I would like to sweep a surface which needs to be parallel to the top plane. I have tried to change the profile orientation to Keep Normal Constant but that didn't quite work the way I wanted it.
See attached screenshots for more info.
Cheers,
Mustafa
Is this pc flat? If it is then offset the centerline in both directions then make the centerline a construction line and make sure the end vertexes are connected to the end lines then do a surface fill and thicken.
