Is it possible to turn off the grid lines for a table in a drawing?
We are adding a drawing to our document package which will list all non-technical drawings related to the project, such as operations & maintenance manuals, technical notes (formal report on a subject/issue), procedures, etc. It is, essentially, a bibliography with a document number for each. Some of the titles will be long and there will be multiple authors in most cases. A table with grid lines will look busy. I don't have to use a table to list these items. But the documents will be grouped by type; and it would be nice to sort them by Doc #, author, date, etc.
I have the same question. In our assembly BOM the numbering convention is: 1, 2, 3, etc for manufactured items, C1, C2, C3, etc for purchased items. Our balloons for the purchased items are set up as circular split line, with the upper text defaulting to 'C' and the lower text is the item number, autofilled from the drawing BOM. In the drawing BOM I have added a column to be filled with a 'C' when it is a purchased item. I would like to hide the grid line between this column and the Item No. column for clarity when referencing the drawing BOM.
Gerald,
Not currently. How would you use this functionality if it did exist?
