Hello
I am trying to complete a thermal study on a "heat exchanger". The results I am getting do not seem right but am unsure of what I am doing wrong in this study.
Looking at the attached photo, I have a contact set between the center pipe at coil with 0 thermal resistance. The steel center pipe is set at 600ºF. There is a convection condition set on the outside of the copper coil of 60 BTU/(s*in^2*ºF) with an ambient temp of 90ºF. What I dont understand is why the temperature of the coil drops almost instantly to the ambient temperature when it is no longer in contact with the main pipe.
First of all i want you to asked this question to yourself:
1. What is clearance between coil and the pipe?
2. Why do you think that the simulation result is wrong do you have an actual data that you trying to replicate or did you have some hand calculation and the result is not the same with the simulation.
To be honest people in this forum will also tell this to you,
"If you do not have actual data or some hand calculation for you to compare with your simulation then"
My Advise is to try to model and simulate a simpler model that can be hand calculated or model and simulate actual model that has data result, so that you can compare the result which will give you confidence in evaluating the result of your study analysis.
why not upload you model and also the way you set up your analysis like boundary conditions etc. for a reference of the people so that they can advise you directly to the point.
