Hi all
I'm having a huge issue with trying to complete a loft. I've tried so many way to complete it but it keeps failing.
I've attached the part file and hopefully someone will see what I'm trying to do along with an image of what it is I'm trying to have it look like (ignore the cut outs). The image was of a file where I used the flex command but it was causing issues in some of the corner so I've had to redesign it and loft it curved instead.
Wayne
Hello Wayne,.. glad you have a solution for this.. it is interesting and agree, multple approaches will give you a better model... I had played with it a bit more with the other ideas or sweep and the core..plus a another section and additional guides.. and came up with something a bit different.. I'm sure there are other ways as well.
