Insert and sort a BOM
Question asked by Charles Winter on Jul 28, 2016
Latest reply on Apr 25, 2018 by Aaron Muizelaar
This code inserts a BOM.  The template, if I insert it manually sorts and pins the BOM, when called in the macro it doesn't, how do I achieve this?  The template is attached.
Option Explicit
Dim swDrawing As SldWorks.ModelDoc2
Dim swFeatMgr As SldWorks.FeatureManager
Dim swView As SldWorks.View
Dim swBomAnn As BomTableAnnotation
Dim swBomFeat As SldWorks.BomFeature
Dim AnchorType As Long
Dim BomType As Long
Dim Configuration As String
Dim TableTemplate As String
Dim Names As Variant
Dim Visible As Variant
Dim boolstatus As Boolean
Dim strViewConfig As String
Dim Filename As String
Dim filetitle As String
Dim checksave As Boolean
Dim lErrors As Long
Dim lWarnings As Long
Set swDrawing = swApp.ActiveDoc
'Check to see if a document is open
If swDrawing Is Nothing Then
        MsgBox "You must have a SolidWorks document open to use this macro.", vbOKOnly, "Nothing is open!"
        Exit Sub
'Check to see if a drawing is open
If swDrawing.GetType <> swDocDRAWING Then
        MsgBox "This macro only works on drawings.", , "Invalid file"
        Exit Sub
'Check to see if the document has been saved
Filename = swDrawing.GetPathName
filetitle = swDrawing.GetTitle
checksave = swDrawing.GetSaveFlag
'MsgBox checksave
boolstatus = swDrawing.Save3(swSaveAsOptions_Silent, lErrors, lWarnings)
If Filename = "" Then
'BOM Tools - Created 4/21/2015 by Chris Manger
'2015.12.08 -  Removed code to check if user is in LMACH, all users are in LM-Test now.
'2015.12.13 -  Updated vault paths to LMEPDM vault
Option Explicit
Dim BomType As Long
Dim lErrors As Long
        Exit Sub
        Exit Sub
'MsgBox checksave
        MsgBox "You must save your drawing first", , "Save Error"
        Exit Sub
Load frmBomMenu
frmBomMenu.Show
Select Case frmBomMenu.Tag
    Case 0
        TableTemplate = "C:\LMEPDM\Engineering\zSysEngLibrary\LM BOM Templates\LM-ASM-WLD-BOM.sldbomtbt"
        BomType = SwConst.swBomType_e.swBomType_TopLevelOnly
    Case 1
        TableTemplate = "C:\LMEPDM\Engineering\zSysEngLibrary\LM BOM Templates\LM-PARTSLIST-BOM.sldbomtbt"
        BomType = SwConst.swBomType_e.swBomType_Indented
    Case 2
        modExportBOM.main
        Unload frmBomMenu
        Set frmBomMenu = Nothing
        Exit Sub
End Select
Unload frmBomMenu
Set swSelMgr = swDrawing.SelectionManager
Set swFeatMgr = swDrawing.FeatureManager
' Select view
On Error Resume Next
Set swView = swSelMgr.GetSelectedObject6(1, 0)
If swView Is Nothing Then
    ' Tell the user that nothing is selected
    MsgBox "Please select a drawing view.", vbCritical, "No View is Selected!"
    End
strViewConfig = swView.ReferencedConfiguration
'MsgBox strViewConfig
AnchorType = SwConst.swBOMConfigurationAnchorType_e.swBOMConfigurationAnchor_TopLeft
' Insert BOM table
