Is it possible to display only components that do not have material assigned?
Related...is it possible to display all components that are a certain material?
Hi Eric.
A macro could help to achieve such result.
Please refer to this example: #CODE|Change Components Visibility Depending On Material
In this example the visibility of components is controlled by material.
Regards
Viktor
Also you could check these free tasks:
"Report part material" to see if all parts in specified folder have not assigned material or mathc written by you material name.
"Assign material" task to change material for all parts.
These task could help to process thousands of files with one click.
http://centralinnovation.com.au/#tab-tools
Hi.
I assume that you are talking about assembly. You can use Assembly Visualization to sort out components by material. Select all parts with cretain materials (or without material) then go back to feature manager (selected components should remain selected) and RMB in 3d space, select Isolate.
Hi.
