Good Morning Everyone,
I am having trouble getting some ducting to flow correctly. It curves up and when it hits that point it goes kind of wonky.
I was wondering if anyone had some tips on how to get it to follow my path. I have tried lofting it and doing a sweep and nothing follows my guide curve in the right way.
Trevor
Trevor,.. I'd run a horizontal guide curve to insure it sweeps properly and gives me the segments.. so, adding a ruled surface normal to a extruded surface (the path)... (btw, if your ruled surface fails or shows wiggle, then your transition path is too tight)
