Why does the select other not work???? If i attempt to select
an edge on a model, all that comes up in the Select Other window
are faces. If I go to the Selection Filter Toolbar and pick the
Select Edges Only button, then attempt to select the edge, it only
selects Faces. I notice this is typical of the glitches that came
out with V. 08 and that SOLIDWORKS is not interested in fixing the
problem. DOES ANYONE HAVE AN IDEA HOW TO FIX??
I checked and found that if I select edge and then select others, it only shows faces and that particular edge in the list. But my filter tool works ok. So I would like to know what SP you are running on. Mine is SP 4.0.
