I need help to figure out what the correct answer is for the assembly question. Attached is the question and the file.
THE CONFIGURATION "CONFIG 1" SHOULD BE ACTIVE.IF NOT,ACTIVATE THE CONFIGURATION "CONFIG 1"
USING BILL OF MATERIALS FUNCTIONALITY, FIND THE TOTAL NUMBER OF COMPONENTS IN THE ENTIRE ASSEMBLY (INCLUDING SUB-ASSEMBLY)
THAT HAVE THE CONFIGURATION "ACME" CURRENTLY ACTIVATED.
NOTE 1: A COMPONENT IS DEFINED AS A SEPARATE PART OR SUBASSEMBLY THAT APPERS IN AN ASSEMBLY.
NOTE 2: AN INSTANCE IS A SEPARATE COPY OF A SPECIFIC COMPONENT.
FOR EXAMPLE, THE "WOODEN SIDE TABLE PLANK" IS ONE COMPONENT OF THE
FULL GRILL ASSEMBLY. SINCE THE WOODEN SIDE TABLE PLANK HAS 14 COPIES IN THE ASSEMBLY IN HAS 14 INSTANCES.
WHAT IS THE TOTAL NUMBER OF COMPONENTS THAT HAVE THE CONFIGURATION
"ACME" CURRENTLY ACTIVATED IN THE "FULL GRILL ASSEMBLY"?
Is this a school project?
